Author Topic: How to check when your car requires a service  (Read 1051 times)
Offline Waqas
« on: 18 August 2009, 15:56 »
hi i wanted to know how to check when my vw golf gti turbo next requires a service.
Last services was at 96,000 and the cars on 100,000
I heard something about variable servicing and some function within the in the menu to find out?  Also checking mpg average not current.
Thanks
Offline richw911
Re: How to check when your car requires a service
« Reply #1 on: 18 August 2009, 19:13 »
Its recommended every 12000 or every year. When was the cam belt and water pump last changed?
The computer will tell you :
http://www.golfgtiforum.co.uk/index.php?topic=62717.0
Also see here:
http://www.golfgtiforum.co.uk/index.php?topic=87370.0
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 18 August 2009, 20:14 »
to be honest the long life/time distance regime is pretty much obsolete for cars as old as the mk4 now. Oil every 5k miles if it's modified, 10k miles if it's standard is a good rule to work by.
Offline Waqas
« Reply #3 on: 19 August 2009, 13:16 »
I know the cambelt was changed at 86000 im not sure about the water pump.
But i know something called a vacum pump was done at 96000.
