Author Topic: Will a MILLTEK exhaust come with a reducer?  (Read 3550 times)
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
« on: 17 August 2009, 21:47 »
EY YUP,
Im lookin to buy a MILLTEK exhaust cat back resonated,
The bore size of the milltek says 63mm,
My bore is 55mm after the cat where it joins at the clamp(this is the original exhaust),
Does the milltek come with a reducer for where it will clamp to the cat?
Please help
1999 GTI 1.8T AGU
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Will a MILLTEK exhaust come with a reducer?
« Reply #1 on: 17 August 2009, 23:22 »
my Blueflame came with one so I would imagine so
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2 on: 18 August 2009, 12:01 »
hello mate.
heres a pic of how my miltek cat back system came when it was delivered hth looking at it there isn't a reducer  :huh: but it fitted to my std cat before i upgraded to the 3" downpipe and sports cat  :wink:
2000 Mkiv GTi 1.8T AGU
Offline D4VEY01
« Reply #3 on: 18 August 2009, 19:14 »
Thanks for the info and pic`s but i need a bit more convincing,its the 8mm difference that i cant get my head around,its got to go smaaler somehow to go onto the cat.
Cheers and any help is greatly appriecated :undecided:
Offline Rhyso
« Reply #4 on: 18 August 2009, 19:58 »
always thought Milltek cat back was designed to fit the OEM cat  :undecided:
they wouldn't offer it otherwise
Offline Steve_PD
« Reply #5 on: 18 August 2009, 20:01 »
mines got a reducer  :wink:
Offline golfgtidan
« Reply #6 on: 18 August 2009, 23:57 »
mine was supplied without it. ball ache to fit without it..
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
Offline jtomlin
  • 1999 AGU 1.8T GTI
« Reply #7 on: 18 August 2009, 23:59 »
make sure you get a fitting kit, and youll be fine!
« Reply #8 on: 19 August 2009, 09:41 »
It should come with a full fitting kit.
  • "1.8T AGU"
« Reply #9 on: 19 August 2009, 14:38 »
iirc mine did just didn't put bag in with the pics  :laugh: :laugh: :rolleyes: :rolleyes:
