Author Topic: engine set up  (Read 1132 times)
Offline parrotveasey81
engine set up
« on: 17 August 2009, 21:32 »
just popped in from the mk2 section as a mate has a mk3 2l 8v that is running rich after a rebuild and i would like to know if there is a tuning guild for his car that i can follow,like the one in the mk2 section.
thanks for any help it will be much appreciated
drive it like u stole it,brake it then mod it
gtigolfthree
adamrob69
Re: engine set up
« Reply #2 on: 17 August 2009, 22:29 »
the mk3 doesnt need tuning. The ECU works everything out. If there is a problem, i'd check the sensors posted in the post above
Re: engine set up
« Reply #3 on: 17 August 2009, 22:45 »
thanks will check the sensors
Re: engine set up
« Reply #4 on: 18 August 2009, 10:09 »
actually it depends on the engine code. if its a 2e it requires setting up exactly the same way as the MK2 8v digi, just you check the CO at the sniffer pipe on the manifold rather than the tailpipe.
Re: engine set up
« Reply #5 on: 19 August 2009, 22:11 »
whats a sniffer pipe
Offline AudiA8Quattro
Re: engine set up
« Reply #6 on: 19 August 2009, 22:32 »
The sniffer pipe comes off the exhaust manifold and allows you to test the emissions of the engine before it goes through the catalyst.
