Author Topic: GTi Mk2 Fuel Pump Query  (Read 1804 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 06 September 2004, 19:31 »
I've just got my second Mark 2, it's been a while since my last one! Is the fule pump supposed to run continuously as soon as the ignition is on. Also should I be able to here it whine from inside the car?
Just wondering if this could be the cause of the excessive fuel consumption?
Also would a drilled airbox also increase fuel consumption, it runs like a bag of spanners on ticker I believe this to be the cause - should mess with something that aint broke!
Rowlers
Offline davidhawkins_78
  • Valver Bad Boy
Re: GTi Mk2 Fuel Pump Query
« Reply #1 on: 07 September 2004, 09:08 »
So, first of all your using more fuel than perhaps u think u should ...
What model mk2 do you have as this does have a HUGE impact !
As for the drilled air box - yes this will caused increased fuel consumption if you have a 'digi' GTi as the air flow meter will register more air and increase the fuel to match, but I very much doubt it'll be a massive increase.
Not so sure on a K Jet though ... I'd imagine it's the same
How many miles u getting to a tank ? Any other mods ?
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Gambit
« Reply #2 on: 07 September 2004, 09:13 »
you should here it prime for 2 secs when you turn the ignition on,
then once the car is started you will not be able to hear it inside the car. though if you stand outside you will hear a small whine coming from just infront of the rear driverside wheel
Offline benjam_in
« Reply #3 on: 07 September 2004, 12:41 »
or a louder one if the bearings are starting to go!
Golf Mk2 Gti 1988
Offline rowlers
« Reply #4 on: 08 September 2004, 19:29 »
Only had it a week, so haven't used a full tank yet. I got about 160 miles on ?25. Sorry it is a 1990 16V. Not sure if it's digital or not - you guys will know!
I guess from one reply that the bearings will be going in the fuel pump cos you can hear it from inside the car (without radio on!)
There is a strong smell of fuel at idel when stationery.
Cheer fellas
Offline Andy Mc
« Reply #5 on: 08 September 2004, 21:34 »
16v will be K-jet.
I get about 250 miles for about ?30 (3/4 tank) on Optimax which is always about 5p per ltr more expensive then normal unleaded.
'90 16v
