Author Topic: Bonding a spoiler to a MK4 gti?  (Read 1713 times)
Offline redevo1
  • golt gti 1.8t AGU
« on: 16 August 2009, 09:23 »
God I've got a golf I'm getting old!Full Recaro leather with arse waming seats, the reason for buying a Golf!Spec: R tech remap:Eibach Fr+Rr ARB:Powerflex ARB bushes:Forge BOF DV:Silicone TIP:Induction kit:Jamex suspension:312mm big brake setup: EBC pads F+R:Vr6/g60 clutch:5mm-fr+15mm-rr spacers: Anni front & rear Valances & Anni rear roof spoiler: Silicone hose boost/Breather kit.
Offline redevo1
  • golt gti 1.8t AGU
Re: Bonding a spoiler to a MK4 gti?
« Reply #1 on: 17 August 2009, 17:32 »
Anyone? Someone must have fitted one?  :smiley:
Offline jonesltd
  • MK7 R
« Reply #2 on: 20 August 2009, 22:12 »
tiger seal!!! did it a while ago and worked a treat...got off ebay...bloody ace!
If you cant find it......Grind it
Offline JDM82
« Reply #3 on: 27 August 2009, 16:58 »
I had the same question so I know what Im talking about.Tiger seal yeah but also I strongly recommend fixing it on with screws to.I got a body shop to fit mine.He used tigerseal and screws and its on solid he told me just tigerseal isn't enough now I dont know if he's right or wrong but I feel alot better knowing its on with screws too.Apparently they are MENT to be screwed on you take the rubber plugs out at the top of the boot lid (just above the rear window) and you will see the marks where the holes are ment to be drilled.
GOLF GTi - The legendary hot hatch
Offline DarkGti
« Reply #4 on: 28 August 2009, 12:14 »
tiger seal is more than enough to hold the spoiler on! have you seen the stuff? i think they used it when they built the starship enterprise! :grin:
