Author Topic: elec window probs  (Read 804 times)
Offline andc1
elec window probs
« on: 15 August 2009, 17:50 »
ok when i got my 3dr anni the drivers window wouldnt work, motor i believe is the common prob, changed that today and still its doing nothing, passenger window works but only on the door button, when i press the pass window switch from drivers door the sunroof closes!!!!!???
any ideas?
Offline VR6-Joe
Re: elec window probs
« Reply #1 on: 15 August 2009, 18:05 »
With the door open, look between the door and the pillar, there's a rubber boot there with all the electrics running through it. Pull the rubber boot back and check that none of the wires are broken..
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline andc1
« Reply #2 on: 15 August 2009, 18:07 »
ok i'll check in a bit, when i press the window button the motor goes for a split second then stops, plugged the new motor in and it does the same, changed the switch and still the same
Offline VR6-Joe
« Reply #3 on: 15 August 2009, 18:09 »
Sounds like a wiring problem then. Are all the wiring plugs connected the correct way around?
Offline andc1
« Reply #4 on: 15 August 2009, 19:17 »
to the switches you mean? yea they only go on one way, i'll check between the doors tomorrow, they dont run on a relay do they?
