Author Topic: Heater control lights aren't working  (Read 2264 times)
Offline Madmax
« on: 15 August 2009, 13:22 »
Hi guys,
2 days ago they were working fine, very dim but fine. Now they're not even lighting up.
I removed the heater & the wiring is all plugged in but can't see any bulbs.
Any diagrams or suggestions please.
Thanks.
Offline VR6-Joe
Re: Heater control lights aren't working
« Reply #1 on: 15 August 2009, 16:27 »
There's a white casing on the back of the heater controls which the wiring is plugged into yes? Pull this off (only 4 clips iirc) and there's a circular green filter made from plastic, the bulb is in the centre of this.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline andc1
« Reply #2 on: 15 August 2009, 18:09 »
you'll need a bit of tube to get the bulb out!!!
Offline VR6-Joe
« Reply #3 on: 15 August 2009, 18:10 »
I just pulled off the green filter and then ripped the bulb out?
Offline Mikester
  • Civic Type R
« Reply #4 on: 15 August 2009, 20:00 »
Have you knocked the dimmer control? lol
Offline Madmax
« Reply #5 on: 15 August 2009, 23:10 »
Thanks for the info people. & no i haven't knocked the dimmer switch. :smiley:
Offline Madmax
« Reply #6 on: 16 August 2009, 13:28 »
Ok. I removed the heater & got to the bulb & it's very dim, is this the bulb or just the power going to the bulb as it's the same on
my mums Polo, the heater lights are very dim. If not i'll get another bulb. :)
