Author Topic: headliner  (Read 1168 times)
Offline match
headliner
« on: 14 August 2009, 20:56 »
can you dye your head liner with fabric dye? and has anyone done this?
nice one
Re: headliner
« Reply #1 on: 14 August 2009, 21:21 »
Don't think it will work as the headliner is card backed.
Offline match
Re: headliner
« Reply #2 on: 14 August 2009, 21:34 »
i've had a practice at the scrappy you can get the fabric off the board no hassle so should be sorted! :grin:
Re: headliner
« Reply #3 on: 15 August 2009, 00:18 »
Yes but you will not be able to restick it, I tried and most glues soaked through.
Offline boneybradley
  • Back in a Mk3...
Re: headliner
« Reply #4 on: 15 August 2009, 00:20 »
buy some cheap material of the bay and "carpet glue" to the original  :wink:
Offline match
Re: headliner
« Reply #5 on: 15 August 2009, 00:26 »
velcro if done right it can work with short stack staples.
Offline _redders_
Re: headliner
« Reply #6 on: 15 August 2009, 07:43 »
what?? are you stupid... staples. would look like a dogs c0ck
the main problems your going to have is A) removing the origional fabric without snapping the roof lining in half, B) once out and you have removed the old fabric, you need to reinforce the roof lining again, as it will be very very floppy, as you've just taken a layer off it. C) you need to remove the old fabric if you are going to retrim it in new fabric, you cant just spray it and stick it on the old stuff, as the extra weight will just pull the old fabric away and it will just sag down. and finally d) finding something you can manipulate around the handle areas and sunvisor area as the are very very tricky, but something that is also quick think and substantional so the glue doesnt soak through. ive trimmed about 10 of these things, hate them.
good luck.
DROP IT LOW . . . ROLL IT SLOW
Offline match
Re: headliner
« Reply #7 on: 15 August 2009, 08:13 »
thats why you use SHORT STACKED STAPLES!And thats why i have said about using the scappy as a practice area its not imposible just tricky but if pulled off will look mint as im not going to have my car lookng like crap.
Re: headliner
« Reply #8 on: 15 August 2009, 10:46 »
good luck.
+1 I had loads of problems recovering mine and in the end gave up and got a s/h lining.
Offline match
Re: headliner
« Reply #9 on: 15 August 2009, 13:11 »
well il have a go and post a picture when done
