Author Topic: mk4 1.8 20v inner cv boot on the o/s/f shaft split.  (Read 2267 times)
Offline AliBailey88
« on: 14 August 2009, 13:13 »
can u change the boot or do you need to change the whole shaft.
if  i remove the shaft will the box oil come pissing out or is that on the n/s shaft??
ta
Offline Steve_PD
Re: mk4 1.8 20v inner cv boot on the o/s/f shaft split.
« Reply #1 on: 14 August 2009, 16:00 »
Am changing my inner boot on my tdi 150 next week, around £15 from VeeW services or around £30 from the dealers
Offline AliBailey88
« Reply #2 on: 14 August 2009, 18:05 »
managed to get one, £14 geuine part, looks easy enough to change, will do it next week maybes.
Offline AliBailey88
« Reply #3 on: 22 August 2009, 18:18 »
Fitted it 2day, was a pain in the arse, ball bearings went fookin everywhere, managed it in the end.
One stupid design i came across is that i had to unbolt the wish bone as i could not get the shocker fully out of the hub, shock came out nicely once the wishbone wasnt attached to the subframe.
