Author Topic: KO3s On A KO3 Map?  (Read 3993 times)
Offline Grand Master Patch
KO3s On A KO3 Map?
« on: 13 August 2009, 21:44 »
Would it be ok to fit a ko3s turbo onto my AGU and run it on the ko3 map(custom code) for a few days?
The idea is to fit everything needed and drive down to R-tech a few days later to have the map etc....
Offline bobbarley
  • I'm kind of a big deal...
Re: KO3s On A KO3 Map?
« Reply #1 on: 13 August 2009, 21:56 »
Fairly sure you could.  Or you could post the ECU to get some standard map on there as a temporary measure.
« Reply #2 on: 13 August 2009, 21:59 »
Posting ecu is not an option,my car is used daily.
Offline bobbarley
« Reply #3 on: 13 August 2009, 22:01 »
I figure it'd either work, or go limp.
Offline T_J_G
« Reply #4 on: 13 August 2009, 22:43 »
Ring RTech patch
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 13 August 2009, 22:51 »
It works fine, don't worry about it. I ran my AGU on a stage 1 revo with a k03s fitted for over 12 months before I got around to changing it.
« Reply #6 on: 13 August 2009, 22:52 »
I keep meaning to,but everyday i get side tracked with work
Offline bobbarley
« Reply #7 on: 13 August 2009, 22:52 »
I almost got something right, YES!!  :grin:
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 13 August 2009, 22:53 »
if you rang with that question the phone would most likely get handed to me anyway :tongue:
« Reply #9 on: 13 August 2009, 22:53 »
That's good to know,can stage2 be done by mobile mapping?
