Author Topic: Few general questions  (Read 2066 times)
Offline sambo
« on: 13 August 2009, 19:58 »
Few questions as I may be buying a DAS 6 machine polisher  :huh:
Can I use a DA to rub in wax on a car?
Whats the differance between waxes and sealants?
Do you glaze a car before you wax it?
Do you have to wash the DA pad's after every go, or can they not be washed? (in a washing machine?)
Cheers, Sam  :smiley:
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline waxamomo
Re: Few general questions
« Reply #1 on: 14 August 2009, 14:31 »
I'll answer them in order for you.
1. You can apply some waxes with a DA but by hand is much easier. Dodo Juice have a wax called Supernatural which is available as a "machine stick".
2. Yes, you glaze before you wax.
3. Yes you have to wash the pad's after every session. You do not want dirt sitting on your pads as you will only end up scratching your car if you don't.
Hope that helps,
Chris
Jkctr
« Reply #2 on: 14 August 2009, 18:27 »
All in my 'sticky' mate with plenty of helpful waxamomo links for good products  :wink:
http://www.golfgtiforum.co.uk/index.php?topic=66113.0
