Author Topic: Mk1 Golf (1.8 Gti) engine tick over problem  (Read 4483 times)
Offline w1nslow
« on: 13 August 2009, 07:45 »
Hello All,
I have a 1983 mark 1 Golf 1.8 Gti that had an engine problem, so I swopped it out for 1984 Sirocco 1.8 Gti engine (the same engine).
As a precaution I had the head skimmed and went about fitting the new engine.  At the same time I changed everything I could, Cam belt, filters, all the service points etc.
Once in the engine starts first time no problem but it wants to kick over between 1500 / 1700 rpm, and when you try and move he car there is no power / torque.  You can move the car but it feels like it is struggling to pull its own weight.
Does anyone have an idea what could be the problem?
Thanks for your support.
gtigolfthree
Re: Mk1 Golf (1.8 Gti) engine tick over problem
« Reply #1 on: 13 August 2009, 09:28 »
Hi welcome to the site, first of all I would recheck the cam and ignition timing.
Offline raferackstraw
« Reply #2 on: 13 August 2009, 11:14 »
then check for air leaks in the intake system and vacuum hoses, high idle can be caused by addition air being sucked in
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline dirtydub
« Reply #3 on: 13 August 2009, 13:33 »
As gtigolfthree says it sounds like a timing issue.
Its quite easy to get the cambelt a tooth out on the camshaft. Also check the timing mark on the dizzy is pointing near spark plug no1 when set at TDC. Its also easy to set the ignition timing 180 degrees out
Make sure ur timing the camshaft up with the marks on the inside of the pulley (facing dizzy side) because there are marks on both sides  :wink:
Rich
'86 golf gti 8v k-jet project up and running :)
