Author Topic: Worn out clutch or normal for golfs?  (Read 2365 times)
Offline monty001
« on: 12 August 2009, 20:18 »
I'm new to Golf ownership... have Mk1 GTi 1983 1.8. Question... the clutch seems to go out a long way before 'biting' - but then all ok. Not slipping, seems fine. Is this normal for GTi? Any comments much appreciated - thanks .... Monty
Re: Worn out clutch or normal for golfs?
« Reply #1 on: 12 August 2009, 21:37 »
You could try adjusting the cable or it could be on its last legs.
Offline monty001
« Reply #2 on: 12 August 2009, 22:12 »
I've had a go at adjustment - but think there's nothing left to adjust. Perhaps it will simply run out completely and I'll have no clutch. Not too expensive I hope...
Ta for advice... appreciated cheers
« Reply #3 on: 13 August 2009, 17:11 »
No worries, clutch is not to expensive or hard to do.
Offline monty001
« Reply #4 on: 14 August 2009, 03:32 »
I adjusted the cable from the white adjuster thingy... and hey presto - clutch bites in middle of travel now! Result...
« Reply #5 on: 15 August 2009, 10:51 »
Good result.
