Author Topic: Wheel arch trims  (Read 2307 times)
Offline stu 88
  • Looking for a cheap set of 17's
Wheel arch trims
« on: 11 August 2009, 15:56 »
Im having the lip rolled on my Gti but am keeping the plastic arches - How are they held on? Is it just the rivets underneith? because that bit of the plastic arch is being trimed so will I have to stick them on?
Offline VR6-Joe
Re: Wheel arch trims
« Reply #1 on: 11 August 2009, 16:03 »
Yes they're riveted. Yes you'll have to glue them on. I glued mine on with Tigerseal.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline stu 88
« Reply #2 on: 11 August 2009, 16:06 »
Thank you  :smiley:
« Reply #3 on: 11 August 2009, 16:17 »
Or leave them off if you refit them they will or may still catch.
« Last Edit: 11 August 2009, 16:20 by Wayne »
Offline stu 88
« Reply #4 on: 11 August 2009, 16:31 »
They wont because Im taking the lip off them
« Reply #5 on: 11 August 2009, 21:16 »
Yes but your problem will be the same I had in that you end up with so little to attach the trim to that it will fall off.
Offline stu 88
« Reply #6 on: 11 August 2009, 21:32 »
Sorry but cant see how the problem will be the same??
Like I said "Im taking the lip off" so obviously I will be sticking the arch to the wing, cant see how it will fall off??
And if I have no lip on the plastic arch or the wing there will be nothing for the tyre to rub on .
« Reply #7 on: 11 August 2009, 21:43 »
When you try sticking the arch back you will see the problem, the arch does not fit flush to the wing at the bottom so trying to stick it is hard enough and trust me the wheel will still catch it as the trim is lower than the lip.
Offline stu 88
« Reply #8 on: 11 August 2009, 21:50 »
Well its being done next wednesday and the bodyshop seem to think they have done it before - time will tell
VW BUSH
« Reply #9 on: 11 August 2009, 21:51 »
Could drill and screw em on like those Proton Satria's :laugh:
