Author Topic: Mk3 Gearbox  (Read 1279 times)
Offline buzzkip
Mk3 Gearbox
« on: 11 August 2009, 12:57 »
Hi all,
I'm having some issues with when changing to first gear. When I attempt to change gear, either of the 3 below happens.
- Gearstick won't get it's arse into first
- The stick moves into reverse territory and feels like the stick just popped out
- It's fine and works
Any ideas would be appreciated!
Changed username from "iAMarshall".
gtigolfthree
Re: Mk3 Gearbox
« Reply #1 on: 11 August 2009, 13:22 »
Check the linkages for wear etc
Re: Mk3 Gearbox
« Reply #2 on: 11 August 2009, 13:37 »
which MK3 is it
Offline buzzkip
Re: Mk3 Gearbox
« Reply #3 on: 11 August 2009, 14:56 »
It's an 8v GTI 1993 Mk3
Re: Mk3 Gearbox
« Reply #4 on: 11 August 2009, 15:34 »
right, linkage is mostly the same as a MK2 so have a read of the linkage faq in the mk2 maintenance section :)
