Author Topic: running problems  (Read 1396 times)
Offline rudeone
running problems
« on: 10 August 2009, 12:50 »
hi all,well where to begin,mk2 gti 91, 8 valve,started having problems with reving and its blowing out black smoke out exhaust so petrol problen somewhere,its as if the car is being suffocated of fuel,you try and rev and its spluttering and can barely rev then will die,and once its died it can be a nightmare to get it started again,i've tried different air flow meter,fuel pressure regulator,plugs,ht leads coil,petrol pump is working as you can hear it and smell petrol,anyone had simailar problems?
gtigolfthree
Re: running problems
« Reply #1 on: 10 August 2009, 12:56 »
Hi, welcome to the site,black smoke and petrol smell would suggest to much rather than to little fuel.
Offline plasticfantastic
« Reply #2 on: 10 August 2009, 12:57 »
Welcome to the forum,
Best bet is to try the search function on the site, someone in the past has probably had the same problem.
Also have a good look through rubjonny's 8v digi tuning guide in the mk2 maintenance section and make sure your car is set up properly first.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #3 on: 10 August 2009, 13:00 »
First of all, how long have you had the car? Did you buy it with problems? Try the digifant tuning set up guide in the maintenance section, but first, buy the blue water temp sensor that you will see coming from the pipe coming from the head and fit that. Get a genuine VAG one as copies cannot be relied upon.
Also look to see if the fuel return to tank pipe is blocked or kinked.
There are hundred of replies to similar problems as the ones you are having and there is a search function to help you sift through the post's. :wink:
Offline rudeone
« Reply #4 on: 10 August 2009, 13:04 »
hi had the car just under 8 yrs no problems in all that time,so can't moan really just doing my head in lol
« Reply #5 on: 10 August 2009, 16:38 »
Welcome to the site.
Black smoke is overfuelling.
Offline Jay
  • balding fat cvnt
« Reply #6 on: 10 August 2009, 16:49 »
welcome
Offline RSCPK
« Reply #7 on: 10 August 2009, 19:23 »
I've seen a lot of posts mentioning the blue water temp sensor. Is this just digi's as I have a k jet??
Offline Ben Lessani
« Reply #8 on: 10 August 2009, 22:08 »
K-Jet, are you religious?
You need to look into the WUR as it can drastically effect fuelling, as well as setting the CO properly (2.0%) on the metering head. Check all vacuum feeds and get the fuel pressure checked.
Plus, a '91 K-Jet, you sure?
Offline Steve_B
« Reply #9 on: 11 August 2009, 12:13 »
That wasn't the OP, Ben  :wink:
RSCPK - yes, only digis have the blue temp sensor
