Sorry the pics aren't the best, really wish i had taken some pics of the loom out of the car. After spending all those hours doing as neat a job as possible, once it was in the car you couldnt see all my hard work, but i guess that was the idea!
here you can see both looms comming from the bulkhead
This is the spur that goes to the coil
I used the original plastic moulded 'T' piece here to send the loom throught the bulkhead on the passenger side and down to the chassis leg
Then both looms are rooted along the chassis leg, wrapped with the original moulded bends again.
Here the loom splits, most goes to the engine plug/knock sensors, and the earth's/power all split seperatly. you can also see the lighting loom.
here, just infront of the battery you can see the mk3 lighting plug i adapted to my lighting loom, i rooted all of the lighting loom down the passenger side and then made a custom front lighting loom incorporating extra relays to take power to all the front lights. this makes it much easier to remover the front end, just undo the big plug and remover power and earths from battery.
i havent got any pics of my finished headlight loom yet, waiting for another roll of vw loom tape to be delivered and ill take it out and wrap it, i'll take pics then!
hope this helps?
