Author Topic: 185/35/17  (Read 1694 times)
Offline stu 88
  • Looking for a cheap set of 17's
185/35/17
« on: 09 August 2009, 20:00 »
In a earlyer post I mentioned that I have a problem with rubbing on the front wheels , its only if I go over a bump  and its on the very edge of the tyre (205/40/17) and Im wondering if I fit a pair of 185/35/17's on the front that it will cure the problem? also whats it going to look like? is that too much of a stretch?
Or another idea I had was to fit 185/35/17's all round a really deck the car??
Offline DAVEMARX
Re: 185/35/17
« Reply #1 on: 09 August 2009, 20:04 »
175 are to thin you want 195 at least..... it will feel like driving on rich tea biscuits..... just shave your arch trims
dave
Offline stu 88
Re: 185/35/17
« Reply #2 on: 09 August 2009, 20:16 »
dave
But how will I be able to hold the trims on? surly the middle bit would need holding on some how?
Offline DAVEMARX
Re: 185/35/17
« Reply #3 on: 09 August 2009, 20:48 »
i ment 185 soz my bad.....
when i done mine on my mk2 i took the acrhes of and used a drimmal hand held router with a little cutting disc on it and just cut of 5mm to 7mm if you look under the arch the plastic trim sticks out from the arch a little.
either take them of or run a drimmel over the inside of the arch trimming of the plastic and use the metal work as a guide but it could take some paint of tho so better to mark a line with a stanly blade  while there on then remove...
Dave
Re: 185/35/17
« Reply #4 on: 09 August 2009, 21:12 »
Tweak the camberso the top of the wheel is further in, worked for me.
