Author Topic: MK3 16v won't start. No spark????  (Read 1106 times)
Offline Phunt
« on: 09 August 2009, 19:31 »
First time poster. I hope someone can help with my problem. My girlfreind and i have just returned from a week on holiday and her car won't start ( it was fine before we went away). We actually ran the battery down trying to get it started so we used jump leads from my car and still no joy. I disconnected the HT lead from the ignition coil and noticed that it is only giving out one spark when the igintion is turned on but it doesn't spark at all when trying to turn over. We went and bought a new coil but it's doing just the same thing. I also tried one of the plug leads with a plug attached to the coil so as to eliminate a bad lead as the problem. I'm at a loss as to what to try next. Any ideas would be much appreciated.
Offline andc1
Re: MK3 16v won't start. No spark????
« Reply #1 on: 09 August 2009, 19:37 »
dizzy cap ok? not wet or split? rota arm ok? plugs all ok not wet or damp, theres a chip inside the actual distrbutor, mk2 's suffer from those breakng up and give the same problem, if thats the case its a new disrtibutor
Offline Phunt
« Reply #2 on: 09 August 2009, 19:40 »
There is no spark from the coil before it even reaches the dizzy.
gtigolfthree
« Reply #3 on: 09 August 2009, 20:37 »
What year is it, Have you done a vag test?
« Last Edit: 09 August 2009, 20:39 by gtigolfthree »
Offline AudiA8Quattro
« Reply #4 on: 09 August 2009, 20:39 »
Try testing the coil for a feed.
Offline andc1
« Reply #5 on: 09 August 2009, 20:43 »
fuses?
