Author Topic: The old b!tch...  (Read 3981 times)
Offline Horney
Re: The old b!tch...
« Reply #10 on: 09 August 2009, 17:22 »
Ha ha ha yeah!
Offline Reasty
  • Alpine white valver.
« Reply #11 on: 09 August 2009, 17:33 »
Mate, sign up to southerndubbers.com and PM a chap called TimG60 on there. Tell him I sent you and I reckon he might be able to help you out with diagnosing your problem. He built and runs a poop hot rallye and has just built a stonking G60 lump for a mates B3 syncro, he knows his stuff. He might be reasonably local to you as well as he lives in the southern area somewhere.
nick
This may well be tim from the phirm,and if so then if ya golfs got a problem, if any man can fix it then he can,the phirm have just moved so are now along the a30 halfway between hook and basingstoke,my valver dosnt go anywhere else when it has to go to hospital  :laugh:
Offline Horney
« Reply #12 on: 09 August 2009, 17:35 »
It's a different Tim but yes the phirm are a good bunch also.
Nick
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #13 on: 09 August 2009, 17:58 »
I have just posted on Dubforce, so hopefully I will get some guidance soon. :embarassed:
Offline AudiA8Quattro
« Reply #14 on: 09 August 2009, 19:25 »
Does the car feel like it is driving in the wrong gear before it clears it throat?
If you hold the accelerator to the floor does it clear itself?
Offline DarnPB
« Reply #15 on: 09 August 2009, 23:14 »
Yes, it clears itself as if someone had thrown a switch at a specific RPM, about 4500rpm. In 4th, that means about 100mph. I have to be going considerably faster than that to make 5th gear seem normal. Difficult with the way its behaving at the moment, but acheivable. :lipsrsealed:
« Reply #16 on: 09 August 2009, 23:41 »
Hope you get it sorted.
Offline Mew
« Reply #17 on: 10 August 2009, 01:00 »
I don't know if this would cause your problems, but have you checked the timing?
Offline wil0
« Reply #18 on: 10 August 2009, 03:08 »
does the g60 ecu work with vag com? would that help you atall?
3Door Oak Green 91 MK2 16v GTi
Offline Diamond Hell
  • Opinions я Us
« Reply #19 on: 10 August 2009, 07:31 »
No, the Dogifant won't work with VAG-COM.
Sounds like it's almost time for you to nail Megasquirt on it.
At least then diagnosis would be a lot easier and you'd be able to tune it rather more effectively.
Have you put up a complete list of what you've replaced?
