Author Topic: Non power steering to power steering  (Read 959 times)
Offline Adam_C
  • Mk4 Golf R32
« on: 09 August 2009, 11:27 »
Hi,
im doing an engine swap at the moment. i have a 1.8 8v gti with power steering and im changing the lump to a 1.9 8v gti so exactly the same just had some work done.
only issue i have is that the old engine has power steering and i was wondering how hard is it to swap over and if i wanted could i just leave it off and run it without powersteering or is the rack different?
cheers in advance chaps.
Offline Jay
  • balding fat cvnt
Offline jamie_pyrite
Re: Non power steering to power steering
« Reply #2 on: 09 August 2009, 12:41 »
Can you not just swap the pulley/pump, etc. over from the old engine to new? I did that but the other way around on my conversion.
Offline Ben Lessani
« Reply #3 on: 10 August 2009, 00:26 »
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg624991#msg624991
et
http://www.golfgtiforum.co.uk/index.php?topic=100369.msg852759#msg852759
The rack is very different,
A gear ratio steering:
   - Free-assisted steering
       20.8
   - With assisted steering
       17.5
The number of turns the steering wheel from lock to lock:
       3.83
       3.17
Even with a drained PAS rack - it would still be pretty darn heavy, much heavier than non-pas. Just throw the PAS bits onto the new engine - its well easy, takes about 10 minutes max!
« Last Edit: 10 August 2009, 00:29 by Ben Lessani »
