Author Topic: 1 way oil valve on inlet pipe, catch tank system  (Read 3586 times)
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« on: 08 August 2009, 23:52 »
my motor has done 60k miles and i pulled my dv out the inlet pipe and noticed a little oil on the bottom of it stuck my finger through the inlet hole and its a little oily in there you think this one way valve is leaking? worth changing, that why its getting a little oil in there?
was goiong to fit my forge relocation kit but il think il wait now...
« Last Edit: 15 August 2009, 12:40 by G60GTI16V »
Offline james2
  • No scammers please.
Re: 1 way oil valve thing on inlet pipe
« Reply #1 on: 09 August 2009, 01:12 »
mine has a little amount of oil in it as well :drool:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 09 August 2009, 10:38 »
its just residue from vapours.. i'm getting ready to rip ALL of that out from mine. Secondary air pump, n249/1112, PCV and EVAP systems. Then feed the breather from the crank cover to a catch tank. Everything was so much simpler when i had an AGU.. too many sodding vacuum dependent systems to f*ck up on an AUM!
Offline G60GTI16V
« Reply #3 on: 09 August 2009, 12:05 »
topher u should let me know in more detail about that system as i was thinking catch tank...
thanks dude
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 09 August 2009, 12:10 »
explaining stuff is not my forte, but i'll be using this as a rough guide http://forums.vwvortex.com/zerothread?id=3111538&page=1
Just going to rip it all out, blank off the hole in the head where the combivalve sits, whack some resistors in the stuff that gets unplugged to avoid open circuit faults and make sure all the important stuff has a decent vac feed from the manifold. Probably going to need to play with the mapping too so I can map out the 'thermal afterburner' like you do with EGR maps so I can avoid any incorrect flow errors that can and do throw up a dash light.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 09 August 2009, 13:57 »
a little like this then  :wink:
« Last Edit: 09 August 2009, 23:31 by richw911 »
Offline Rhyso
« Reply #6 on: 10 August 2009, 09:14 »
how much have you emptied out since fitting that out of interest?
was thinking of fitting a catch tank to mine - too much oil around the intercooler and egr for my liking really  :undecided:
« Last Edit: 10 August 2009, 09:40 by Rhyso »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 10 August 2009, 17:31 »
tried emptying the catch tank just after I fitted it and only got one drip but I've done a fair few miles (well for me anyways) since then so I'll empty it out and show you the results later
Offline G60GTI16V
« Reply #8 on: 11 August 2009, 18:58 »
wazzer have you had all the electronic stuff sorted out like toppher has described to have this plumbed?
thanks
« Last Edit: 11 August 2009, 20:04 by G60GTI16V »
Offline Rhyso
« Reply #9 on: 12 August 2009, 07:50 »
thanks
no need as he has an AGU  :wink:
