Author Topic: steels to alloys  (Read 2729 times)
Offline holmesy777
steels to alloys
« on: 08 August 2009, 10:19 »
just wonder if going from standard steel wheels to a set of avus 2 alloys will i need to replace the wheel bolts as well?
haven't got the car yet so want to get new bolts(if required) to put them straight on!
cheers.
Re: steels to alloys
« Reply #1 on: 08 August 2009, 10:24 »
cheers.
If the alloys are reps then yes you will need new alloy bolts with a different taper.
Offline holmesy777
« Reply #2 on: 08 August 2009, 10:47 »
thanks for that. Alloys are genuine so i take it my original bolts will do the job?
« Reply #3 on: 08 August 2009, 11:35 »
Check the bolts, should be rounded taper if so then they will be fine.
