Author Topic: Mayo on underside of oil filler.  (Read 2474 times)
Offline scurbo
« on: 07 August 2009, 18:52 »
Just got back after a 8 hour trip around manchester area looking at mk3 and mk4 golf gti's. The final one i looked at was a mk4, but i noticed a white residue under the oil filler cap and inside as you looked down. The car ran perfect, nothing unusual, it was a 1999 1.8gti, is this normal, so i know for next time.
Offline Steve_PD
Re: Mayo on underside of oil filler.
« Reply #1 on: 07 August 2009, 18:54 »
Could be the head gasket has gone  :undecided:
gtigolfthree
« Reply #2 on: 07 August 2009, 19:00 »
Yes its water that turns oil white.
Offline Mr_Orange
« Reply #3 on: 07 August 2009, 19:37 »
Can't it also show up just after a short journey too?
Build thread clicky
gtigolfthree
« Reply #4 on: 07 August 2009, 19:39 »
Yes but I think its just condensation that causes that.
Offline johnson6672
« Reply #5 on: 07 August 2009, 19:40 »
It doeas happen if the car does lots of short journeys as the engine doesn't get hot enough to burn it off, but you really need to do pressure tests to confirm head gasket or other sinister things.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
gtigolfthree
« Reply #6 on: 07 August 2009, 19:46 »
Yes I wouldnt diagnose a head gasket on one symptom you would need several of the following mayo as mentioned but also white oil(water in the oil), overheating, water consumption, water pressurising, loss of compression/performance etc.
« Last Edit: 07 August 2009, 19:47 by gtigolfthree »
Offline Dubbz
« Reply #7 on: 07 August 2009, 19:56 »
yeah as said. could be a number of things that cause "mayo".
Two different brands of oil will cause that, as well as condensation, or worst case a head gasket.
What service history did it have?
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline Stu-1.8T
  • Quit your Jibba Jabba
« Reply #8 on: 07 August 2009, 20:27 »
My 2.0 has this and it's only on 50k with full history/regular oil changes, but apparently most suffer with it.  Condensation forms as the heat cant escape from the top of the engine quickly enough.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #9 on: 07 August 2009, 20:50 »
Money's on condensation if there were no signs of overheating.  Did the temp. guage stick on 90 deg. after a run?
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
