Author Topic: on idle  (Read 4189 times)
Offline match
Re: on idle
« Reply #10 on: 07 August 2009, 19:07 »
it is single point i ran an injector cleaner through it (redex)
Offline AudiA8Quattro
Re: on idle
« Reply #11 on: 07 August 2009, 19:07 »
Is that single point injection as opposed to multi on a gti, how does that work then?
yes..
well its like a carb, but it has one injector that feeds all 4 cylinders unlike gti's that have one injector per cylinder.
Correct.
However everything is controlled by an ecu, that's where it differs from a carb.
Re: on idle
« Reply #12 on: 07 August 2009, 19:09 »
A couple of suggestions.
Check for any vacuum leaks around the injector unit.
Also there is a throttle potentiometer with a built in idle switch on the injector unit.
Offline match
Re: on idle
« Reply #13 on: 07 August 2009, 19:21 »
thanks will have a look for splits and whats this switch?
Re: on idle
« Reply #14 on: 07 August 2009, 19:54 »
Next to the where the throttle cable mounts is a 4 pin connector.
Disconnect it, put a multimeter set to resistance on the bottom 2 pins.
With the throttle slightly open it measure not more than 200 ohms.
With the throttle shut it should measure infinity.
Offline match
Re: on idle
« Reply #15 on: 07 August 2009, 19:58 »
and if not?
Offline match
Re: on idle
« Reply #16 on: 07 August 2009, 20:09 »
I dont suppose you have a diagram?
Re: on idle
« Reply #17 on: 07 August 2009, 20:36 »
A feeler gauge is used to test the switch in this diagram.
Offline match
Re: on idle
« Reply #18 on: 07 August 2009, 20:40 »
how about this mate
idle stabelizer valve on the front of spi unit
do you know anything about this?
Offline ace
Re: on idle
« Reply #19 on: 07 August 2009, 20:45 »
if it has an isv, i would try cleaning it out and seeing if that makes a difference
