yes mate. disconnect for 30 minutes, then connect back up, then turn ignition on but do not turn the car on for 5 minutes, then with the ignition still on turn the car on for another 5 minutes. Do not press the throttle at all at any time, let it idle for 5 minutes. If you have the cold starting problems then do this when the car has been run for a while so it starts when you reset it without having to hold the accelerator.
