Golf mk3
hardmonkeys
Front wheels rubbing the arches?
Topic: Front wheels rubbing the arches? (Read 2433 times)
stu 88
Here all the time
Looking for a cheap set of 17's
06 August 2009, 22:43 »
Ive just fitted some coilovers on my mk3 Gti and when turning if I hit a bump the front wheels seem to rub somewhere?? I cant see where though, Could it be the plastic wheel arch trims? Is it poss to trim it?
Any idea's??
Thanks
Adam
Forum addict
Re: Front wheels rubbing the arches?
06 August 2009, 22:44 »
Wayne had to trim his, he will be here in abit.
how low and what size are your wheels?
Down Hill From Here.
shepgti
first off what wheels are they? and whats the offset? and yes you can have the inner arch bits trimmed and rolled
Reasty
Alpine white valver.
06 August 2009, 22:45 »
You should be able to see on the tyres if its catching and also if you feel on the inside of the arch you should be able to feel it aswell.
stu 88
Here all the time
06 August 2009, 23:03 »
Its about 60mm/70mm Im running 205/40/17's and the wheels have a offset of ET35
Wayne
Sir Postalot
06 August 2009, 23:28 »
Quote from: stu 88 on 06 August 2009, 23:03
Yours is the same drop and spec wheels I was running, I ha issues with fron and rear arches, you cannot really trim the plastic arch back as it leaves you with nothing to mount it back on with, in the end removed the arches.
I lived with it to be honest.
VR6-Joe
Reply #6 on:
07 August 2009, 00:33 »
I did looooads of arch mods to get mine low. Was approximately 110mm in the end, on 17's
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Mikester
Forum addict
Civic Type R
Reply #7 on:
07 August 2009, 05:40 »
Wheels rubbing. Welcome to the scene and car modifying. Lol
stu 88
Here all the time
Reply #8 on:
07 August 2009, 09:52 »
Think Im just going to live with it
christomk3gti
Reply #9 on:
08 August 2009, 14:31 »
If it aint rubbing, it aint dubbing.
Black 8v GTI............. Whats a Waffle Valve?
Golf mk3
hardmonkeys
