Author Topic: Rear Shocks and Rear Discs !!  (Read 1025 times)
Offline leegt5
« on: 06 August 2009, 21:43 »
Was advised on my MOT that my rear shocks and bump stops could do with changing... While Im doing that is there any other parts of the rear suspension I should renew at the same time ??
Also how hard is it to change the rear discs ? I've done them before on other cars but haven't had to renew the wheel bearing at the same time. Are the bearings a right pain or not too bad ??
Re: Rear Shocks and Rear Discs !!
« Reply #1 on: 06 August 2009, 21:47 »
Rear top mounts.
Rear discs are not to hard, you will need or it is better to fit new wheel bearings, you might need a press but should be able to knock the cups in and out all ok.
Offline christomk3gti
« Reply #2 on: 06 August 2009, 21:47 »
lol my thread is quite similar to this. and put up the same time... quite freaky that lol....
Black 8v GTI............. Whats a Waffle Valve?
