Golf mk3
hardmonkeys
dashboard errors
Topic: dashboard errors (Read 2574 times)
karl29
dashboard errors
06 August 2009, 14:09 »
hi can anyone help me after cleaning my throttle body and all pipes changed spark plugs now i have an error on the mileage display which says Cerr could someone please help me sort this out its dcoing my head in thanks for any help anyone can give me
Adam
Forum addict
Re: dashboard errors
06 August 2009, 16:19 »
Means there is an error reading the mileage from the clocks, the mileage is stored on the clocks so worst case is mileage correction to sort the problem. Just try unplugging them for a while.
Down Hill From Here.
karl29
06 August 2009, 17:59 »
thanks will give it a go and let you know what happens also vag com comes up with intermittent fault on throttle position sensor and intermittent on air intake only thing different i did today was clean the earths on the engine
Adam
Forum addict
06 August 2009, 18:03 »
Did you clear the codes and rescan?
karl29
06 August 2009, 18:52 »
no not sure how to i have a vagcom thing but i only know how do the basics will it clear the error on the dashboard if i do
Golf mk3
hardmonkeys
dashboard errors
