Author Topic: downpipe - URGENT!!!!  (Read 1332 times)
Offline Grim_Reaper
  • warningz...i haz powaz
« on: 06 August 2009, 12:50 »
guys, my flexi join has split on my 1.9 non turbo diesel, what other downpipe can i use??? i had a spare DP from a 1.8 8v but the flexi was useless on that too  :sad: :sad: :sad: :sad:
will any other DP fit??? a bit of welding isnt a problem for me  :wink:
gtigolfthree
Re: downpipe - URGENT!!!!
« Reply #1 on: 06 August 2009, 13:05 »
Check your engine mounts, if the engine moves it pulls at the flexi pipe.
Offline Grim_Reaper
« Reply #2 on: 06 August 2009, 13:09 »
that not the answer im after :laugh:
gtigolfthree
« Reply #3 on: 06 August 2009, 13:49 »
Mabye not but if you dont get that sorted first then the engine will pull apart any exhaust that you try to fit. If the mounts are worn every time you accelerate and decelerate the engine moves back an forth puling at the exhaust.
« Last Edit: 06 August 2009, 13:56 by gtigolfthree »
« Reply #4 on: 06 August 2009, 15:46 »
From memory non turbo diesel is a lot different to the rest of the range.
Offline Grim_Reaper
« Reply #5 on: 06 August 2009, 15:48 »
true but my mounts are fine, first thing i checked ;)
thats the problem im having, but ive made a solution and that is to weld a new flexi to the old flange and DP
