Author Topic: Clutch slipping  (Read 1564 times)
Offline Tubb
Clutch slipping
« on: 05 August 2009, 18:00 »
Hi all,
My clutch started slipping earlier in the year so i replaced it with a new Sachs around March time.
It was fine up until about a week ago when i noticed it slipping in 3rd, 4th and 5th gears at around 4500rpm when the cam picks up - this is what the old clutch did.
I thought it might have been the cable that needed adjusting so tried that but it didnt make any difference.
Now today its started slipping in every gear and an any rpm  :cry:
Is it likely that the cable is causing it to slip (i have a spare one in the garage) or is there anything else it could be?
The oil seals have be changed and its a MK1 020 gearbox.
Typical that it would happen as im supposed to be driving around europe all weekend  :angry:
Thanks in advance
1987 Golf GTI 16v 2.0 - 1993 Autocavan Demo Car - For Sale!
1992 Pulsar GTi-R
Offline jezza16v
Re: Clutch slipping
« Reply #1 on: 05 August 2009, 18:30 »
Well, the cable would cause it to slip if it was not releasing properly. You need to have about 5mm free play between the cable end and the release arm to ensure the pedal pressure is completely off. Any oil leaks from the clutch housing? Did you replace the pressure plate with the clutch? The flywheel surface may be 'glazed'.........or worn too deeply.   :undecided:
Re: Clutch slipping
« Reply #2 on: 05 August 2009, 21:02 »
Crankcase oil seal failed and coating the clutch with oil maybe.
Offline Tubb
Re: Clutch slipping
« Reply #3 on: 05 August 2009, 23:11 »
Yes i replaced the pressure plate, friction disc and bolts which came as a kit. Flywheel also looked fine
This has been replaced by a previous owner and there we no signs of oil when i changed the clutch 6 months ago.
It just seems strange that all of a sudden its started slipping when it been fine for 6 months. same as the old clutch, was fine and then suddenly started slipping.
Ive got a new clutch cable in the garage so il try and change that tomorrow afternoon
1992 Pulsar GTi-R
Offline danny_p
Re: Clutch slipping
« Reply #4 on: 05 August 2009, 23:19 »
if the clutch was slipping loads before you tryed to adjust it it will have trashed itself
all the VW's have gone bar 1.
Re: Clutch slipping
« Reply #5 on: 06 August 2009, 11:25 »
did you replace the pushrod brass bush & seal, plus the input shaft seal? if not it might be gearbox oil thats leaked onto the clutch
http://www.brokevw.com/020seal.html
Offline Tubb
Re: Clutch slipping
« Reply #6 on: 06 August 2009, 12:44 »
no didnt change that  :angry:
thanks for the link
1992 Pulsar GTi-R
