Author Topic: lubricants for use with detailing clay  (Read 3666 times)
Offline Wurzel
« on: 05 August 2009, 00:57 »
What are they usually? I've seen some clays where it is advertised that they can be used with water as a lubricant, whereas other clays come with expensive lubricant sprays.
1999 mk4 1.8 n/a AGN Silver Grey
***Looking for one 16 inch wheel, Montreal 2*** and a rear parcel shelf (without speaker holes!)
Offline Guy
Re: lubricants for use with detailing clay
« Reply #1 on: 05 August 2009, 08:02 »
just use a QD spray (which you can water down to make it last longer) or you can use dodo born slippy
http://www.waxamomo.co.uk/productcart/pc/viewCategories.asp?idCategory=4
Offline waxamomo
« Reply #2 on: 05 August 2009, 09:34 »
Yep as Guy said above, any QD will do the job.
Chris
Offline Guy
« Reply #3 on: 05 August 2009, 09:42 »
didn't i put in the same linky?  :laugh:
Offline waxamomo
« Reply #4 on: 05 August 2009, 09:54 »
Oops sorry  :rolleyes:
Offline jmsheahan
« Reply #5 on: 05 August 2009, 10:12 »
As said above didn't have any probs with dodo born slippy. At the end of the day though it's only lube.
Offline Wurzel
« Reply #6 on: 05 August 2009, 18:49 »
Yeah that's why I'm asking about water, because the lubes are pretty expensive when you think about it.
Offline Dan34
  • VTEC Powerzzzz
« Reply #7 on: 05 August 2009, 19:03 »
i just use water seems to work alright.
Dan
Offline Saint Steve
« Reply #8 on: 05 August 2009, 19:41 »
Autoglym Shampoo watered down works very well. :smiley:
Offline waxamomo
« Reply #9 on: 05 August 2009, 22:23 »
As far as I know there is only one clay on the market which is made to be used with just water and that's Bilt Hamber. All others are made to be used with lube,I for one would not use it without as i'd be too scared to marr the paintwork.
