Author Topic: help any ideas to my mk 1 rivage starting problem  (Read 2096 times)
Offline billygolf
« on: 04 August 2009, 21:05 »
 :smileyhi ime sarah  i have a k reg mk 1 rivage convertable i have been the owner for 13 years the problem is once the car has been running and then left for more than 5 mins it struggles to start it keeps keying over then when it finally starts its missing as if its running on 3 cylinders after it clears it runs sweet ime woundering if its running low compression i put a aftermarket main fuel pump on it from euro could it be this i pretty much know all the history of my car but this is driving me mad it is still running the k jet injection system anyone had a similer problem please help thanks
Offline kraM
  • It's not the speed, it's the sudden stops...
Re: help any ideas to my mk 1 rivage starting problem
« Reply #1 on: 04 August 2009, 22:19 »
When it starts, does it belch out black smoke from the exhaust?
Does it do it when the engine is warm, or straight from cold?
Have you ever run it out of juice?
Does it start ok first thing in the morning?
Check all the vaccume hose connections, as the braded rubber hose's fail after a while,
I am not sure on the latest K-jetronic systems, but the idle air control valve may be stuck, the temp sensor for the warm up valve may be on the blink, the pressure regulator may be knackered too. (sorry the list is loooong)
Or, when was the last time you had it serviced?  It could just be knackered plugs/leads etc?
kraM
It's not the speed... it's the sudden stops...
Offline gibby
« Reply #2 on: 05 August 2009, 18:58 »
Could also be the fuel pump relay or maybe even the old rusty filler neck.
To check the fuel relay, take the relay out (I think it's the top left relay, but could be wrong) and look at the connections, if it's full of melted black from your fuse box then sandpaper the connections, put back in and see what happens. Then always carry some sandpaper in the car just in case. :wink:
......now officially dubless.
Offline raferackstraw
« Reply #3 on: 06 August 2009, 02:14 »
did the after market fuel pump come with an accumulator as what you have sounds like a residual pressure problem
the accumulator sits between high pressure pump and metering head and once engine is warm and switched off the accumulator holds the pressure inthe system to allow sufficent fuel at the injectors to fire when hot, if there is insufficent pressure the heat from the engine will vaporize what little fuel there is in the actual injector lines so causing the hot start problem
does it eventually fire after after alot of cranking?
it will start ok from cold as the cold start valve compensates for the low pressure
hope the above helps but ask rubjohnny as he's the mk1 guru who told me the above info which solved my problem
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
« Reply #4 on: 06 August 2009, 11:36 »
need to get a pressure gauge on it to confirm if its an accumulator problem, but it does sound liek that could be it. might be leaky injectors too?
Offline drego786
« Reply #5 on: 09 August 2009, 10:51 »
your injectors are leaking into the combustion chambers and flooding the engine / spark plugs are getting wet .
start the car wait for fans to kick in swich off engine wait the normal time  remove spark plug and see if it is wet
