Author Topic: rear brake problem  (Read 11349 times)
Offline gtiscott
Re: rear brake problem
« Reply #10 on: 04 August 2009, 21:52 »
really p****d of with the car right now, just spent a fortune getting it through an mot, one week later the front break pad split and now this :angry: :angry:
once again thanks for the replys guys
scott
VW BUSH
« Reply #11 on: 04 August 2009, 22:39 »
+2, dangerous to drive in current state.
And ilegal   :sad:
Offline harlemex
« Reply #12 on: 04 August 2009, 22:58 »
Your (so called) mechanic probably re-used your old calliper bolts instead of new ones. He may have over torqued them too. These bolts are under a huge amount of torque and when removed become weaker and so should be replaced. You could sue the garage for this serious safety issue. You should get them to do it properly this time and ask for all your money back. You know it makes sense.. :wink:
« Last Edit: 04 August 2009, 23:05 by harlemex »
VW BUSH
« Reply #13 on: 04 August 2009, 23:09 »
Most likley left them undone, (takes a lot to push a bolt past its elastic limit.) are your wheel nut tight as well :lipsrsealed:
Offline AudiA8Quattro
« Reply #14 on: 04 August 2009, 23:26 »
You can re-use any of the bolts fitted, neither are stretch type. The caliper bolts need to be coated with thread lock if re-used, the allen key type bolts that hold the carrier can be re-used also.
I think from the picture the allen key bolt has come out, as it appears the whole assembly has pivoted up.
The problem may be it hasn't been tightened to a high enough torque.
« Reply #15 on: 04 August 2009, 23:27 »
+1 I always use loctite on caliper bolts.
« Reply #16 on: 04 August 2009, 23:31 »
I'm sure i read somewhere that vw used thread lock on the allen key bolts on mk3's. Thats why they are so damn difficult to get out.
« Reply #17 on: 04 August 2009, 23:45 »
I am sure they do plus I believe new bolts come coated with loctite as well.
Offline harlemex
« Reply #18 on: 05 August 2009, 00:15 »
Its the slide pin bolts that have loctite on them and these bolts must NEVER be re used. The allen bolts are the calliper mounting bolts and do not need loctite. It is worth replacing these as the heads are sometimes damaged when undoing and could round off. For the sake of a couple of quid why wouldnt you replace these anyway? We are talking about safety after all?
« Reply #19 on: 05 August 2009, 09:40 »
The slide pin bolts don't need to be replaced at all. They just need a fresh coating of loctite.
If you get new ones with new pads/discs, use them, if not just re-coat the old bolts.
« Last Edit: 05 August 2009, 09:46 by AudiA8Quattro »
