Author Topic: Ultima Brand Now in stock at Waxamomo  (Read 2447 times)
Offline waxamomo
« on: 04 August 2009, 14:01 »
The range can be found here:
http://www.waxamomo.co.uk/productcart/pc/viewCategories.asp?idCategory=40
What's The Big Deal?
A car maintenance program can’t be easy if it’s complex.
Until now, the only viable way to maintain your car's paint, trim and interior surfaces was to apply waxes, dressings and other protectants every 30-45 days. Doing a full detail of your car this way is a full day affair.
There is a better way, it's the Ultima Finish Care Program.
There has never been a car care system as easy and effective as Ultima.
From the very moment you try it you'll recognize that it's not simply different. Ultima is Clearly The Best!
Ultima products are easier to use, last longer and offer better looking results, Guaranteed!
Get Your Weekend Back!
Using advanced nanotechnology polymer sealants (patents pending) you can now shine and protect every surface of your car in a matter of minutes.
If your vehicle isn't in perfect, like-new condition, Ultima has quick and easy solutions for all of your cleaning and polishing needs, too.
With Ultima, You Simply Wipe It On, Then Walk Away!
You read correctly.
The Ultima application process is as easy as wiping the sealant on the surface of the car. There is nothing to buff off. Ultima sealants dry clear and take on the natural, original look of the finish.
Protection and beauty have never been this easy and have never looked this good.
What Makes Ultima Different?
Until now, all car appearance care products required two laborious steps: wipe on and buff off. Ultima removes the second step and makes the first step easier.
Every Ultima sealant product wipes on with ease and dries to a perfect final finish. No buffing is necessary. Simply wipe the product on, and walk away!
Over the life of your car, Ultima saves you time and money. Plus, your car is going to look great.
« Last Edit: 04 August 2009, 14:35 by waxamomo »
Offline Guy
Offline waxamomo
Re: Ultima Brand Now in stock at Waxamomo
« Reply #2 on: 04 August 2009, 14:36 »
Oops thanks Guy, all sorted now  :smiley:
