Author Topic: misfiring problem  (Read 1958 times)
Offline steble
misfiring problem
« on: 03 August 2009, 20:40 »
we appear to have a bit of a misfiring problem with the gti cabrio
i've changed the dizzy cap, rotor arm, leads, and plugs
it does it on acceleration but not all the time
i was thinking maybe coil, or dirty injectors (run some redex through it)
Offline kraM
  • It's not the speed, it's the sudden stops...
Re: misfiring problem
« Reply #1 on: 10 August 2009, 23:08 »
check all your vacuume hoses, if the advance has come off the dizzy/inlet manifold, that'll do it...
kraM
It's not the speed... it's the sudden stops...
Offline raferackstraw
« Reply #2 on: 11 August 2009, 03:33 »
also check ignition amplifier  its the little box that screws on top of the ecu
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline nicksvw
« Reply #3 on: 12 August 2009, 21:56 »
my mk3 had the same problem found out it was a split breather pipe on the inlet manifold
Offline steble
« Reply #4 on: 13 August 2009, 01:04 »
cheers guys i'll check these tomorrow, dont know what the ignition amplifier is i'm not used to ecu's i play with mini's i'm sure i'll find it.
thinking about it i dont recall seeing a vacuum hose which would explain things
« Reply #5 on: 13 August 2009, 11:21 »
ecu should be under the scuttle tray on passenger side its about the size of a fag packet
