Author Topic: wheel bearing change  (Read 4254 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 02 August 2009, 21:29 »
Hi all, I need to change both my front wheel bearings.I just wondered if its a garage job or is it possible to do it myself??.I have done the rears just the fronts to do now. Any help would be good
cheers mark
Offline mr self destruct
Re: wheel bearing change
« Reply #1 on: 02 August 2009, 21:59 »
As DIY jobs go mate, I rate it only slightly more difficult than wiping dead flies off the headlights.  :wink:
A-reg mk2 gti, first registered 01-05-84.
Know of any earlier mk2s?
Offline AudiA8Quattro
« Reply #2 on: 02 August 2009, 22:06 »
Time for some proper advice  :grin:
Fronts are difficult, probably impossible in most cases, without a press.
Best bet is to strip the hubs off yourself and take them to a garage.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #3 on: 02 August 2009, 23:14 »
+1.
You can do it in an extremely large vice, but unless you know what you are doing, I would not recommend it.
« Reply #4 on: 03 August 2009, 09:27 »
+2 you really need a press.
Offline 01664gti
« Reply #5 on: 03 August 2009, 10:15 »
cheers lads,Im ok with stripping them off etc.I might aswell put new disc and pads on while im there,But just wasn't sure about the bearing. definatley got to change them as one of them is sounding a bit rough,thanks for your help.
« Reply #6 on: 03 August 2009, 10:26 »
yeah if it was me i'd have both hubs off the car and pop into a local garage with new bearings in hand, should press em in & out for cheap :)
Offline robz
« Reply #7 on: 03 August 2009, 10:29 »
as above - take the hubs off and take them to be pressed -
i got charged £20 for one to be pressed in!!
dont really think it is worth it trying to press it in yourself... what happens if it aint in properly or straight, lol
Offline dan_apps
  • too low for british roads!
« Reply #8 on: 03 August 2009, 10:30 »
mine are getting pressed in next week by a local engineering company for the grand sum of........................2 cans of beer! :shocked:
:afro:
« Reply #9 on: 03 August 2009, 10:39 »
I've got my own press  :tongue:
