Author Topic: Views required.  (Read 9738 times)
Offline JC
  • Back in the North.
Views required.
« on: 02 August 2009, 11:37 »
Right, the valver is currently parked up since its got a  " alledged " tappet / lifter issue.
I have been told by 5 people including 2 time served VW Techs that its the lifters, at least  in one area.
but now 2 other people say it isnt, and could be a more serious engine issue.
So, I have options .
1, get all new lifters fitted either @ a garage of by one of the very nice men on here.  - Costly option and wont neccesarilly fix the thing.  :lipsrsealed:
2, use the set of lifters from my spare engine - was a known healthy engine on removal ( only got the guys word on this ) , cheaper than option one and if it DOES cure it i can always get new ones fitted at a later date.
3, get a set of lifters from elsewhere ( danny you still got them ? ) to prove the fault diagnosis as per option 2.
4, give up and break the fcuking thing  :grin: :laugh:
Awaits the abuse, and then the 3 or 4 helpful posts  :cool:
Offline Mew
Re: Views required.
« Reply #1 on: 02 August 2009, 11:48 »
I'd go with option 2 to start. It's the cheapest option (free!)  :wink:
Offline JC
Re: Views required.
« Reply #2 on: 02 August 2009, 11:58 »
yeah, was the way i am heading, will stick a new cambelt and tensioner on mind, incase it cures it [finger crossing mod on ]
Offline AudiA8Quattro
Re: Views required.
« Reply #3 on: 02 August 2009, 12:29 »
I would go with option 2.
Why not do the job yourself?
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Views required.
« Reply #4 on: 02 August 2009, 12:31 »
What other 'serious' issues could be afoot then? If they were serious, then the engine would have let go by now. If it was piston slap, then you would have a more prnounced sound at engine speed, but your problem is at half engine speed and tappets are hit at half engine speed. :huh: :huh:
If you are worried about your engine, then remove the oil filter and split it open. Remove the card element and open it out to look for debris. Then make your choice.
Having listened to the engine and knowing what I am talking about, I still say it's tappets, and tappets do get lazy and noisy with age.
Offline DarnPB
Re: Views required.
« Reply #5 on: 02 August 2009, 12:39 »
One more thing. If you use used tappets on a different engine, you could cause camshaft wear as tappets wear into camshafts. You put these same tappets into another engine, the wear has to take place again, but in different places as no two items are identical.
You can fit new tappets to an existing camshaft, but if you require a replacement camshaft, you will need new tappets too. :wink:
Offline JC
Re: Views required.
« Reply #6 on: 02 August 2009, 12:41 »
as i said gents, after views,  she i started her up today it was HORRIFIC.
did the oil filter thing last time, - nowt but i change the oil and filter every 6 months anyway
Offline DarnPB
Re: Views required.
« Reply #7 on: 02 August 2009, 12:46 »
Well with the info now to hand, you could make an educated decision yourself. I think it would be a real shame to break a perfectly good car for the sake of a set of tappets.
You could fit the tappets from your spare engine purely as fault diagnoses, then if the fault is found, remove them and fit new ones. Free fault diagnoses without the prospect of spending un-necessary cash.
Offline Khare
  • The bear that khares
Re: Views required.
« Reply #8 on: 02 August 2009, 12:52 »
I agree with DPB. I also heard you're engine at the shady meet a few months back and it did sound like tappets.
Also, I'd do the job myself, not as complicated as you think and much more satisfying than watching someone do it.
Offline johnson6672
Re: Views required.
« Reply #9 on: 02 August 2009, 12:56 »
just out of curiosity, whats wrong with your spare engine? could you not fit that?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
