Author Topic: F.p.rs  (Read 2705 times)
Offline dubslug
F.p.rs
« on: 02 August 2009, 10:36 »
Hi huys when i get my dub back i wanna sort out thr fueling issues, are there any bolt on up rated frps from other cars i could add to my 91 plate digi engine?? with out needing any mods??
cheers all
1992 pearl grey 8v
Offline fused
Re: F.p.rs
« Reply #1 on: 02 August 2009, 16:37 »
not sure but doesn't the G60 one bolt straight on.....? is a high pressure oneer i'm sure.
Re: F.p.rs
« Reply #2 on: 03 August 2009, 10:02 »
g60 one is same as the normal mk2 one, its the injectors that differ. summut out of a porche or aftermarket is wat u want. are you going to get the ecu remapped to suit though, as just doing that on its own wont get you anywhere!
Offline danny_p
Re: F.p.rs
« Reply #3 on: 03 August 2009, 11:23 »
you can fit a riseing rate FPR  they help digi 2 engines, shoveing one in thats just a higher pressure is a bad idea   it'll get more fuel EVERYWHERE   thats awhat we did to TC's motor  but it makes it run excessivly rich on cold start and it has caused a bit of a torque hole but it can be driven through and the coldstart / idel dosnt really matter as it's a track car,  bad idea on a daily tho
« Last Edit: 03 August 2009, 17:44 by danny_p »
all the VW's have gone bar 1.
Offline Diamond Hell
  • Opinions я Us
Re: F.p.rs
« Reply #4 on: 03 August 2009, 12:50 »
cheers all
What ARE 'the fueling issues'?
Offline dubslug
Re: F.p.rs
« Reply #5 on: 04 August 2009, 17:28 »
it leans out at top end, was told uprating fpr would help, then been told to change injectors etc, so confused
1992 pearl grey 8v
Offline Mew
Re: F.p.rs
« Reply #6 on: 04 August 2009, 17:34 »
Typical digifant characteristic isn't it?
Offline dubslug
Re: F.p.rs
« Reply #7 on: 04 August 2009, 17:46 »
yeah but my engine is now running following specs
2.0l 2e bottom end
bvh from man in shed
stainless manifold
stainless exhaust
k&n panel filter
guys at rolling road say i can get more outta it if i sort fueling out
1992 pearl grey 8v
Offline Mew
Re: F.p.rs
« Reply #8 on: 04 August 2009, 17:48 »
I just meant that they all do it incase you didn't know, rather than thinking yours alone has a problem :wink:
Offline DOA
Re: F.p.rs
« Reply #9 on: 04 August 2009, 17:57 »
Neither of your suggested fixes are going to work properly, they will just make the mixtures wrong everywhere else (ie, where you actually use your engine), the real cure is a re-map though thats not a simple thing to do apparently. DannyP's suggestion might improve things a tad but its not the solution. Your only real option is to find someone to do you a custom chip or swap to a different injection setup though if you go the chip route Id wait till you put a better cam in there (Im assuming that since you didnt mention it you havent swapped the stock one out yet).
