Author Topic: Noisy exhaust !  (Read 2888 times)
Offline Andy-H
Noisy exhaust !
« on: 02 August 2009, 08:45 »
Right, I've just put on Powerflow cat-back exhaust on the 8v. From the outside the exhaust isn't too noisy but inside there is loads !!
I have ordered some dynamat type stuff to line the boot with. Is this going to help much ?? The only other alternative is to replace the back box for a bigger silencer but I don't want to go through the expense of that again really  :sad:
Any help or advice greatly received
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline gtiscott
Re: Noisy exhaust !
« Reply #1 on: 02 August 2009, 09:30 »
i have the same problem, although i got the mid section replaced and they put on a 'smaller' one and from the outside it sounds fine but on the inside it sounds like a tank :angry:
scott
Re: Noisy exhaust !
« Reply #2 on: 02 August 2009, 09:34 »
Hate to say this but thats powerflow for you, I had a system once and took it off after only 6 weeks.
Offline Andy-H
Re: Noisy exhaust !
« Reply #3 on: 02 August 2009, 09:39 »
Do you not think the dynamat will help Wayne ?? The noise seems to be all coming from the boot. I'm also going to do under the rear seat.
'91 Tornado red Mk2
Offline christomk3gti
Re: Noisy exhaust !
« Reply #4 on: 02 August 2009, 12:06 »
lol, i'm fitting my cat back powerflow system tomorrow, i hope mine aint gunna sound like a tank lol.
I'll keep u posted.
Black 8v GTI............. Whats a Waffle Valve?
Offline Andy-H
Re: Noisy exhaust !
« Reply #5 on: 02 August 2009, 15:03 »
You just have to find the right revs  :grin: if you are going between 2500 - 3000 revs on either heavy load or over running it seems to be worse then, just like a vibration noise from the back end of the car. Other than that it isn't too bad  :wink:
'91 Tornado red Mk2
Offline Mikester
  • Civic Type R
Re: Noisy exhaust !
« Reply #6 on: 02 August 2009, 16:52 »
I have cat back powerflow, its possible the worst money i have ever spent.
It will be coming off when funds allow.
Offline Andy-H
Re: Noisy exhaust !
« Reply #7 on: 02 August 2009, 16:56 »
I have the old stainless back box I had on before that I'm thinking about putting back on to try and reduce some noise  :sad:
Worst thing is i have to set off to North Wales at 5 in the morning  :shocked: gonna be deaf by the time I get there.
'91 Tornado red Mk2
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
Re: Noisy exhaust !
« Reply #8 on: 02 August 2009, 17:38 »
andy mk3, where did you get that grill from for your car it looks sick!?  p.s hope the exhaust works out!
VW BUSH
Re: Noisy exhaust !
« Reply #9 on: 02 August 2009, 19:46 »
How big is the mid box? My PFlow is quiet, i did ask for it to be though
Worst thing i found with Pflow is that the rubber mounts they used were shocking also i had to adjust the position of the exhaust after a few months especialy when i fitted new mounts.
Exhaust is nice and tidy though pointless :smiley:
« Last Edit: 02 August 2009, 21:43 by VW BUSH »
