Author Topic: digifant  (Read 1993 times)
Offline Winner
digifant
« on: 01 August 2009, 19:39 »
 :cry: Can any1 help me plz!! i hav golf with digifant in it an its not injecting fuel on crankin i have wired them up to battery they all work fine and tryed them on different ecu and still nothing. does any1 no if there is a sensor to tell ecu to tell injectors when to inject or anything like this? i did think bout hall sensor but from what i can tell this just controls spark. PLZ I NEED HELP!!
PS its defently an electrical fault somewhere
Offline danny_p
Re: digifant
« Reply #1 on: 01 August 2009, 20:06 »
digifant 2 needs a tach signal to work.
if it dosent see ignition signal from hall sensor it presumes the enigne isn't running hence no fuel
all the VW's have gone bar 1.
Offline Winner
Re: digifant
« Reply #2 on: 01 August 2009, 20:20 »
so basically i should check hall sender an maybe replace it u would say?
Offline Winner
Re: digifant
« Reply #3 on: 01 August 2009, 20:23 »
Offline jezza16v
Re: digifant
« Reply #4 on: 01 August 2009, 20:36 »
Are you getting a spark at the plugs? Is the fuel pump priming? Could be a fault with the ECU relay?
Offline Winner
Re: digifant
« Reply #5 on: 01 August 2009, 20:51 »
got 1 spark from coil when turn ign on and  earth it then thats it. dint think its relay but dint think there was 1 4 ecu and fuel pump is all gd think thats wat u asked to check
Offline jamie_pyrite
Re: digifant
« Reply #6 on: 02 August 2009, 01:28 »
You're looking for Relay 32 for the ECU and 80 for the fuel pump :)
Have you tried checking with a multimeter you're getting anything through the the injector electrical plug? Is the wiring on it OK?
Re: digifant
« Reply #7 on: 03 August 2009, 10:00 »
does the rev counter jiggle when engine is turning over?
Offline Winner
Re: digifant
« Reply #8 on: 03 August 2009, 21:54 »
Hi thanks for all your help  :wink: i found the problem an it was a bad connection on 1 of the wires on the hall sensor hope this can help anyone else in the future.
Thanks again people  :smiley:
