The garage
Faulty shock absorber?
Topic: Faulty shock absorber? (Read 2147 times)
GregUK
GTI forum regular
2001 Golf GTI 1.8T AUM 150bhp in Diamond Black
01 August 2009, 16:01 »
Hi
I'm after a bit advice about a problem I've just noticed on my wife's Lupo. The top mount of one of the rear shock absorbers is protruding 10cm further than it should into the boot, almost as if it has hyperextended. Is this a sign that the shock absorber has failed, or is there another component that is supposed to limit the upward travel of the shock?
Out of interest, I removed it to test. The shock still retains it's damping properties and doesn't appear to have leaked any fluid.
Thanks
AudiA8Quattro
Forum addict
Re: Faulty shock absorber?
01 August 2009, 16:29 »
Sounds like the top place or mount has failed. You should be able to tell if you have it in bits.
gtigolfthree
Guest
01 August 2009, 16:34 »
Photo would probably help.
GregUK
GTI forum regular
01 August 2009, 16:54 »
Quote from: gtigolfthree on 01 August 2009, 16:34
Sorry for the poor quality camera phone pic:
GregUK
GTI forum regular
01 August 2009, 17:03 »
I've just had a look on ETKA and there's a "snap ring" which fits to the groove which is visible in my photo.
Could it be something as simple as that?
Wayne
Sir Postalot
01 August 2009, 17:15 »
Seen that before on a Polo the snap ring had failed.
Agreeable Slick
Global Moderator
Serious forum addict
Unit
Reply #6 on:
02 August 2009, 18:15 »
Yes it is that.
Happened to mine a while back. Get it done as soon as possible, as it will strain the other and will need to get both done.
Garages can replace just the snap ring if you ask them too, or just drop the rear out and do it yourself.
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
GregUK
GTI forum regular
Reply #7 on:
02 August 2009, 23:08 »
Thanks for your help, everyone. I'll get a couple of these ordered.
The garage
