Author Topic: CAN-BUS GATEWAY? FOUND IT! NOW NEEDS CODING! PLEASE HELP!  (Read 8496 times)
Offline HasH
Hello, as in my last post i was asking about the can-bus. now i have the part but cant find the original to be able to change it. my dash is in bits right now, the passengers and drivers side and it not going back together till i find it lol!
im hoping somebody knows cause its driving me mad!
thankyou
« Last Edit: 01 August 2009, 17:13 by HasH »
Offline Saint Steve
Re: CAN-BUS GATEWAY? WHERE THE F**K IS IT??? PLEASE HELP!
« Reply #1 on: 01 August 2009, 12:05 »
above the drivers footwell, above pedals somewhere from memory.  :smiley:
Offline Hurdy
« Reply #2 on: 01 August 2009, 12:07 »
Sure you aren't getting mixed up with the OBD II port Steve?
Seat Leon Cupra Black 290 DSG
Offline Saint Steve
« Reply #3 on: 01 August 2009, 12:37 »
When i had issues with my 1st Rns, seen pictures of it under there john, unless the O.P's after something else?
Offline cameluk
« Reply #4 on: 01 August 2009, 15:08 »
Isn't it behind the centre console?
On LHD its in the drivers footwell but on RHD its in the middle
Offline HasH
« Reply #5 on: 01 August 2009, 15:33 »
bingo! thanks phil!
NOW! Can somebody help me with the coding. iv just scanned with vag com and its all gone nuts. i have no idea what my new coding should be! heres part of the scan...
Saturday,01,August,2009,14:43:48:38283
VCDS Version: Release 805.4
Data version: 20090602
Chassis Type: 1K0
Scan: 01 03 04 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN:    Mileage: 81070km/50374miles
01-Engine -- Status: Not registered 0001
03-ABS Brakes -- Status: Not registered 0001
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
09-Cent. Elect. -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0001
16-Steering wheel -- Status: Not registered 0011
17-Instruments -- Status: Not registered 0001
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Not registered 0001
42-Door Elect, Driver -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0001
46-Central Conv. -- Status: Not registered 0011
52-Door Elect, Pass. -- Status: Not registered 0001
56-Radio -- Status: Not registered 0011
7D-Aux. Heat -- Status: Not registered 0011
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 290609F1000784
   Coding: 00000000000002000000
   Shop #: WSC 00000 000 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 15
                    Mileage: 81077 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:51:22
« Last Edit: 01 August 2009, 15:43 by HasH »
Offline HasH
« Reply #6 on: 01 August 2009, 16:18 »
I have managed to code parts of it...now just need help with the remainding ones...
Saturday,01,August,2009,17:05:36:38283
VCDS Version: Beta 907.2
Data version: 20090726
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: ****************   Mileage: 81070km/50374miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000012
   Shop #: WSC 00046 412 294912
2 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication - Intermittent
   Coding: E9801F16000202000001
   Shop #: WSC 12345 123 12345
2 Faults Found:
01207 - Control Module for Auxiliary Heater (J364)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 81077 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:44:11
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 81077 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:44:09
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 00C802087F2D8405485AC69010CC
   Shop #: WSC 00046 412 172032
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
4 Faults Found:
00830 - Convertible Top Control Module (J256)
01517 - Control Module for Trailer/Towing Sensor (J345)
            005 - No or Incorrect Basic Setting / Adaptation
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
1 Fault Found:
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 01000000    Serial number: VWZ1Z2I6168720
   Coding: 0100040004
   Shop #: WSC 01357 011 00200
2 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 542 km
                    Time Indication: 0
                    Date: 2001.14.14
                    Time: 19:27:44
00821 - Antenna 2 for Radio (R93)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 542 km
                    Time Indication: 0
                    Date: 2001.14.14
                    Time: 19:27:44
1 Fault Found:
« Last Edit: 01 August 2009, 17:23 by HasH »
Offline HasH
Re: CAN-BUS GATEWAY? FOUND IT! NOW NEEDS CODING! PLEASE HELP!
« Reply #7 on: 01 August 2009, 18:51 »
PANIC OVER! I think i have sussed it! no fault codes as of yet. a short drive and a rescan will soon tell me!
Offline DanoGTI
« Reply #8 on: 03 August 2009, 10:31 »
Phew! Glad about that - wanted to help, but all I saw was a bunch nosensical numbers!!! :grin:
If you need an idiot's opinion, I'm your muppet! :grin:
Dan
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline AlanD
  • MK5 2.0T 16v
« Reply #9 on: 03 August 2009, 11:22 »
Have you tried turning it off and back on again? :D :D
Glad you got it sorted in the end lol
