Author Topic: after some window squiter parts, help needed! MK3  (Read 2256 times)
Offline insane
« on: 01 September 2004, 17:10 »
Hi all i know this isn't the wanted parts section
but wondered if you can help me identfi the parts i need first, before i ask for them
Bascially!
1 - I need a plastice pipe that goes from the window washer bottle to a connector, which then goes to the squirters
2- on the back squiter, the bit that fire it at the window, has snapped, so water just dribbles everywhere,
anyone know what this is called, or which parts i need
do i have to replace a big section or is there just a certain part
photo below
many thanx
all the best
Ben
:D
actually! while i am at it!
as you can see in the picture above
some basket tried to break into my empty boot at one stage
and has knackered the plastic bit that runs along the top of the number plate
any ideas what that is called, so i can order one
also
the lock on the boot, the springs have gone inside,
can this unit be replaced, leaving original key barrel?
thanx again
Ben
:D
« Last Edit: 02 January 2005, 01:25 by insane »
Offline JMallows
Re: after some window squiter parts, help needed! MK3
« Reply #1 on: 01 September 2004, 19:34 »
The tubing you can get from B&Q or places like that cheaply... Or expensive from a car shop.
I thought the boot thing was called a grab handle, but that might bew somethig else.! Yes, you can order just the bit you need and keep the existing key, or go to VW and give them your key/lock number, and will order one for your keys.
A clever person solves a problem. A wise person avoids it.
Offline insane
« Reply #2 on: 01 September 2004, 21:50 »
wicked thanx for info mate
:D
still puzzled on the back washer jet thing!
Offline JMallows
« Reply #3 on: 02 September 2004, 12:32 »
Thats cool, i just hope i was a help!
Offline insane
« Reply #4 on: 25 October 2004, 00:29 »
anyone?
Offline Adam-D
« Reply #5 on: 25 October 2004, 09:14 »
theres 2 things either the tubing has gone you can get that at hafords
or the jet itself has gone
you also can get it from halfords
and i didnt know vw could order me a new boot lock thats good cos mine is stuffed
Offline Helios_Blue_Valver
« Reply #6 on: 25 October 2004, 18:13 »
I think i would just go to the scrappy and get the parts you need honestly. I bought two of the rear lock surrounds and a couple door handles for 5 quid. I used two of the rear bits to make a single smoothed delocked one. Take care.
mrwotto
« Reply #7 on: 25 October 2004, 21:52 »
the rubber tube you need, go to a pet shop and get some air pipe for a fish tank, will be loads cheaper than halfords, and same diameter
Offline insane
« Reply #8 on: 02 January 2005, 01:28 »
Nice one cheers for info guys
 :smiley:
