Author Topic: Engine Full of petrol need help.  (Read 4411 times)
Offline miket84
« on: 31 July 2009, 14:51 »
Hi all i changed my gearbox last night and now the car wont start, Thought it was the starter motor as it was locked solid, took that out and it all seemed fine, Then i noticed a puddle of fuel around the air filter housing.
Ive took the air filter off and the inlet manifold was pouring fuel out, so i thought id better take the plugs out to clear the bores and a 3ft blast of fuel came out No4 plug hole.
I have absolutley no idea whats causing this but my fuel pump used to prime then stop but now its just on constanly, is this my problem???
I'm going to try now to change the relay but im a bit worried as my mrs drives the car alot.
Any help, suggestions would be great as i need it running again asap.
Cheers, Mike
Re: Engine Full of petrol need help.
« Reply #1 on: 31 July 2009, 15:24 »
I'll take a guess and say your car is a digifant 8v? what you have done is fry your ecu, check the gearbox earth! if the connection is missing or dirty this is what happens :(
Offline miket84
« Reply #2 on: 31 July 2009, 16:17 »
Yep it was missing, tried a new relay and nothing, but i do have a spark.
Is this a comment thing then??
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #3 on: 31 July 2009, 16:25 »
it is - i managed to miss the earth off as it was ihdden behind my battery - looked for any loose connections etc and didnt notice it in the stress/heat of the moment and fried my ecu.. new ones available on ebay all the time for pennies compared to breakers prices!  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline hasekna
« Reply #4 on: 31 July 2009, 16:42 »
I've got an 8v ecu if you want it, it came off a running car. You can just send me a self addressed padded envolope or somthing (because I'm lazy) if you want and ya can have it for free?
Offline miket84
« Reply #5 on: 03 August 2009, 17:49 »
That is very kind of you, i've been on the phone all day today to many vw breakers in the midlands area but no-one seems to have one or be bothered to look, there appears to be about 50 different part numbers/types of 8v ecu, Mine is a digifant 2 with th part number 037 906 022 DB, Do you know the part number of yours??
There is one on ebay now but ive been e-mailing the owner and had no response. Im without a car now and ive been told i have to flush theoil out twice to avoid premature engine failure.
Offline Mr Blue
« Reply #6 on: 03 August 2009, 18:36 »
ive fitted diffrent part number ecu's to mine. all worked.
That free ECU is nice of the man :smiley:
Offline miket84
« Reply #7 on: 03 August 2009, 19:31 »
So could i just try any ecu off a mk2 8v?? Im intrigued? Would it cause any damage?? I dont want to cause any damage as the car is immaculate, or was lol.
And yes it was very nice of the man, But i'll be sure to add a nice drink!
Offline miket84
« Reply #8 on: 03 August 2009, 19:56 »
ok im still searching the forum trying to find ways around my problem, ive been offered a superchip for my ecu and have been told this will fix my problem, does anyone know the truth in this??
Would me changing the chip fix my problem??
Offline Jay
  • balding fat cvnt
« Reply #9 on: 03 August 2009, 20:02 »
I'd stop wasting time and get a SAE in the post to the kind man ASAP  :wink:
