Author Topic: Ignition switch issue?  (Read 9052 times)
Offline stu 88
  • Looking for a cheap set of 17's
« on: 29 July 2009, 23:59 »
I've been told Mk3's can have a problem with the ignition switch? Is this true? What happens? I'm wondering if that's the problem with my car not starting and not a immobiliser fault??
Offline Mikester
  • Civic Type R
Re: Ignition switch issue?
« Reply #1 on: 30 July 2009, 00:02 »
What will happen is you turn the key all the way to the notch before start, everyhing lights up, and then when you twist it one more to start it. It wont start the car.
Signs of wear are if you have to turn the key hard, apply pressure, or have to twist it to far.
Mine went and eventually you couldnt start the car without twisting the key in an exact way.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 30 July 2009, 00:04 »
put the key in and wobble it around..see if any lights flicker on the dash (also try the wobble when trying to start it too...i warn you there a pain to fit if it is faulty!!)
Offline Mikester
  • Civic Type R
« Reply #3 on: 30 July 2009, 00:07 »
I paid someone to fit mine. It was like £19 for the part. And £90 labour. At a TRUSTED auto electrician.
Offline Adam
« Reply #4 on: 30 July 2009, 00:11 »
cost me £20 to have mine done and that was including the part, and it was at a VW garage.
If it was an ignition fault it would turnover but not start?
Down Hill From Here.
Offline Mikester
  • Civic Type R
« Reply #5 on: 30 July 2009, 00:12 »
no mate.
That is like igntion relating to engine electrics not sparking the engine.
The igntion switch is in the barrel of the lock that you turn the key in to start it.
« Reply #6 on: 30 July 2009, 00:13 »
I replaced the complete inner column on mine looked to be the best way forward.
Offline stu 88
« Reply #7 on: 30 July 2009, 00:19 »
Would it suddnly do that? it seemed to be fine then 30 mind later it wouldn't start?
Offline Mikester
  • Civic Type R
« Reply #8 on: 30 July 2009, 00:21 »
Not really. Mine progressed over months really.
But then again, one day i would get it right, next day i would have to try 3 times to hit the switch right.
Its hard to explain, but once its replaced you realised just how buggered it was.
Offline VR6-Joe
« Reply #9 on: 30 July 2009, 08:26 »
Immobiliser fault - I removed the chip from my key and then attempted to start the car to see what would happen if I ever did have problems with the immobiliser. The car turned over and fired up, although died straight away. As soon as I put the chip back in the key and started the car, it ran perfectly again. Is yours doing that?
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
