Author Topic: power steering pipes  (Read 2398 times)
Offline av8r
« on: 29 July 2009, 21:43 »
My power steering pipes are corroded and need replacing. The cost of ONE of the pipes from VW is £187+VAT!! From a different perspective this would be called extortion. Does anyone know of an alternative supplier or pipe fabricators who could manufacture copies for a reasonable fee?
Offline Adam
Re: power steering pipes
« Reply #1 on: 29 July 2009, 21:46 »
They run a high pressure so would need to be up to a lot. But still £187+VAT! just wow.
Have you thought about getting some from a breakers yard or from someone breaking their golf on here?
Down Hill From Here.
Offline av8r
« Reply #2 on: 29 July 2009, 21:55 »
Adam, I thought about breakers etc but theres not a lot of point if they are part corroded already, and i'd be back to square 1 in a couple of years. This must happen to other Golf's......my general question is are people just paying up to get it fixed or is there an alternative?
Offline Adam
« Reply #3 on: 29 July 2009, 22:00 »
You could try -
http://www.powersteeringstore.co.uk/hoses.htm
Or find a local hydraulics company and I'm sure they can do something
Offline av8r
« Reply #4 on: 29 July 2009, 22:19 »
Thanx for the link i'll give them a call! I was told (correctly or not i don't know) that a lot of hydraulic/pipe manufacturers won't touch "one off" car pipes just in case the part fails in a safety critical situation and they get sued for damages.
« Reply #5 on: 29 July 2009, 23:44 »
100% correct, all to do with HSE and if the item they had made were to fail.
And before people say well they make hoses for big machines, if the hose were to fail then the burst or check valve will stop the boom or load dropping.
VW BUSH
« Reply #6 on: 30 July 2009, 00:08 »
Dont tell em its for a car :smiley:
Say its for an ejection cylinder on a Netstal they will believe that :wink:
« Reply #7 on: 30 July 2009, 00:12 »
Not as easy as that, most machine hoses fittings are BSP but cars tend to be Metric.
Offline filthy
« Reply #9 on: 30 July 2009, 20:48 »
You could try -
Thanks for posting the link Adam!
av8r- I can make em for you- high pressure hose is £70, low pressure hose is £60...just give me a call on 07917 697262
« Last Edit: 30 July 2009, 20:51 by filthy »
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
