Author Topic: clutch  (Read 2043 times)
Offline nicksvw
clutch
« on: 29 July 2009, 13:12 »
 my wife pressed the clutch down today then nothing? any ideas ?rac man said could be the pin? thanks
Re: clutch
« Reply #1 on: 29 July 2009, 13:34 »
Could be the cable snapped or the release arm inside the gearbox.
Offline Khare
  • The bear that khares
Re: clutch
« Reply #2 on: 29 July 2009, 13:36 »
does the clutch pedal stay pressed down or does it come up again as normal?
If it stays pressed down (by the spring behind it) then cable could be snapped or the clutch cable clip could be broken.
Offline Adam
Re: clutch
« Reply #3 on: 29 July 2009, 13:38 »
Does it jump when you start it in gear?
Down Hill From Here.
Offline nicksvw
Re: clutch
« Reply #4 on: 30 July 2009, 20:23 »
The pedal stays down.
Re: clutch
« Reply #5 on: 30 July 2009, 20:30 »
If the cable is ok then the release lever inside the gearbox has failed.
Offline boneybradley
  • Back in a Mk3...
Re: clutch
« Reply #6 on: 30 July 2009, 22:54 »
and if its an 8v I have the full kit you need to repair the ratchet (going cheap :wink:)
Re: clutch
« Reply #7 on: 30 July 2009, 23:58 »
It might also be the clutch that has failed.
Offline nicksvw
Re: clutch
« Reply #8 on: 04 August 2009, 12:10 »
thanks for all info.had it in garage they said was clutch now tells me end of gearbox is shaged anyone got a gearbox close to sheffield? can contact me on 07971087774 as away from pc most of the time. thanks nick
Re: clutch
« Reply #9 on: 04 August 2009, 12:20 »
I would seek a bit more advice, if it is the release lever then it is repairable.
