Author Topic: found another abf donor that is being held for me  (Read 1771 times)
Offline richard s
found another abf this time its in a seat ibiza he will chop the front end off behind the shifter and give me everything in front of it  so what does this mean in terms of wiring is it a case of unpicking the lighting loom or is there more stuff wired in
it has a transponder key and aircon so i take it its a later model as i cant remember what year it is
Re: found another abf donor that is being held for me
« Reply #1 on: 28 July 2009, 16:05 »
if it has the transponder it'll be a later model around 96ish is when they got fitted over here.  depends what seat it came from some have the lighting loom in with the engine loom some have it seperate, you'll see when you get it delivered!
Offline kittie
« Reply #2 on: 28 July 2009, 17:16 »
Good luck with the ABF conversion, I want to do the same on my mk2  :grin:
Offline richard s
« Reply #3 on: 28 July 2009, 18:52 »
its an ibiza gti 16v and he is bringing me all the shell now instead of cutting it in half and it is coming on thursday or friday  :smiley:
Offline richard s
« Reply #4 on: 28 July 2009, 20:00 »
does the rear engine mount need chopping or does the engine sit level without/what front mount do you use and is the ibiza widetrack
cheers
Offline plasticfantastic
« Reply #5 on: 28 July 2009, 20:13 »
Main difference with the ibiza loom is the ecu sit on the passenger side instead of the drivers side.
once you have unpicked the lighting loom from it, its pretty much the same as the golf loom, although colours may vary on the wires compared to the fusebox faq!
« Reply #6 on: 29 July 2009, 10:26 »
shouldnt need to mess with the mounts if you fitr a std manifold + downpipe, some aftermarket 4 branch hit tunnel due to them being designed for a short block kr not tall block abf.  if you get whole car this means tank, pump & lines included too, which is handy if your car not a gti already :)
Offline richard s
« Reply #7 on: 29 July 2009, 16:17 »
cheers guys
wiring wise i was thinking about labelling all the plugs as i take it out and then once out identifying the lighting plugs fusebox end and start removing from loom does this sound about right or is there a better way that you guys use
cheers
« Reply #8 on: 29 July 2009, 18:16 »
thats about it to be honest,
lighting plugs are easy to identify in the fusebox, they are all yellow, white plugs are the engine loom.
Offline richard s
« Reply #9 on: 29 July 2009, 18:32 »
cheers dont sound to bad but im sure i will get stuck on something at some point
