Author Topic: MK6 GTI Day Light Running lights  (Read 30256 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: MK6 GTI Day Light Running lights
« Reply #40 on: 26 September 2009, 18:57 »
Im confused by a couple of the posts on page 3 about DRL with the xenons on the GTI, is it simply the small little ~ type light below the main xenon thats on for DRL or are you saying the xenon is as well? Is that ~ light the DRL or side light? Im confused  :undecided:
« Last Edit: 26 September 2009, 19:05 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline HA54SYM`
« Reply #41 on: 28 September 2009, 12:47 »
Note the two styles of Xennons, I guess the dark style will be the final ones as one the IAA car. But what is the DRL on normal GTi Xennons then?
Dave
94 - Roversport Tomcat Racecar
Offline daviescotland
« Reply #42 on: 03 March 2010, 18:27 »
Resurrecting an old thread.
Has anyone with Xenons managed to turn the DRL's off?? I'm looking to do this asap so any advice would be good.
Davie
MK6 GTI, 3 door, candy white, 18" monza shadow, Xenons, RCD 510 w "dynaudio", sunroof, rear view camera, cruise control & free servicing.
Ordered 28/10/2009. BW07 confirmed. production complete 10/02/2010. Arrived at dealers 17/02/2010. Driving on a 10 plate 01/03/2010.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #43 on: 03 March 2010, 19:01 »
DRLs can be activated/deactivated by using the headlamp lever.
Ignition off. Lights to 'O'. Left turn on indicator (down) while pulling back (flashing mainbeam), switch on ignition, hold for 4 seconds or so and you should here a beep. The DRLs are now off.
To reactivate is similar but you use Right turn on indicator (up) instead.
Its also in the manual
Mk6 GTI  &  Mk1 GTI
« Reply #44 on: 03 March 2010, 19:04 »
Hi snoopy. i saw that in the manual and on a search on here, but it doesn't seem to work. Just wondering if anyone had actually done it or not for xenons? Not sure if that makes a difference.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #45 on: 03 March 2010, 19:06 »
I switched them off on the demo car i had. :evil: I think thats was what i used. :undecided: Did you hear the beep and did you have the light switch in off?
« Last Edit: 03 March 2010, 19:08 by Snoopy »
Mk6 GTI  &  Mk1 GTI
« Reply #46 on: 03 March 2010, 20:42 »
Yes, followed the instructions.
I'll give it another go tomorrow. car gets it's first coat of polish tomorrow also  :smiley:
